MS2 High Boost Switch?
Real simple question for you guys, I just dont know how to implement it.
Currently I run about 10psi on wastegate, and have my map tuned up to 30psi. I want to be able to run on wastegate and when I need more power have the ability to hit a button or flip a switch and have it jump to my high boost settings. Is this possible? How can I accomplish this if so? I am using an Electronic 4port Boost controller.
Thanks!
Thanks!
Re: MS2 High Boost Switch?
Put a switch on the power wire to the boost solenoid and off should be waste gate pressure if plumbed correct
Sent from my SM-G955U using Tapatalk
Isn't that what the throttle is for?
Or are you wanting a "Valet Mode"?
No one is going to hit 30# in a parking lot.....
Are you looking for less power than "On the spring" gives?
Andy
Andy
I think he wants the 30psi on a switch for "when necessary". If it's tuned for 30psi, (as stated above) you can have a switch in-line with the boost solenoid to keep it deactiveated and cruise around on low boost, then flip it to activate the solenoid for high boost.
1990 Mustang: MS3Pro Gen 1, 306ci, 72mm turbo, 80lb inj, 36-1 + Cam Sync + D585 coils, World heads, TFS1 cam, GT40 intake, auto, Speed Density
1987 Mustang: MS2v3.57, direct coil control, MSD VR Dizzy, SBE, Weiand 174,190cc heads, F303 cam, TBI w/ (4) 160lb inj, GT500 MAF
Dose the electronic boost controller allow you to change boost from inside the car?
David
David
Looks like ms2 only has a single table for boost control. So cutting power to solenoid to run wg line then back on to get boost control
