I have a vw scirocco 8v and I'm looking into getting microsquirt for it. I wanted to know if I need a pull up resistor to run it in the car to work properly and if so where can I find it?
Sent from my SM-G955U using Tapatalk
Microsquirt pull up resistor
Re: Microsquirt pull up resistor
1k between signal and tps vref for vw hall sender. Available from your supplier.
Ok saw your website site and I already have the 3bar map
I believe there is room to install the pull up resistor inside the case of the squirt.
I know I've seen a picture of it but could not find it in the manual.
