VW Bus EJ20T
VW Bus EJ20T
Hello,
I have a Westfalia 76 with a Subaru EJ20T engine. The engine runs as I installed a non turbo ecu and it starts and accelerates fine. However I can't get any RPM Crank signal in 32-2-2-2 or Subaru 6/7 crank settings. If I use EDIS setting I see RPM values but they are really high. At one point it started with these settings but it was stating 2k-3k rpm when it was idling. Not sure how to make the Microsquirt read the correct rpm.
Can anyone help?
Luis
Can anyone help?
Luis
Re: VW Bus EJ20T
The Google says it should be a 36-2-2-2
Re: VW Bus EJ20T
What crank trigger wheel do you have? I had to buy the 36-2-2-2. Mine came with that 6/7 style one and I read that there had been some problems with it. So I just bought the 36-2-2-2 one to avoid problems.
MSQ ?
MSQ ?
'65 VW Bus with a Subaru EJ20 Turbo conversion , Air to water I/C , LS coils , 14Point7 Spartan 2 & Solid Air Fuel Ratio 52mm gauge.
MS2 Extra V3.0 board
Re: VW Bus EJ20T
I believe it's a Subaru 6/7 since it's a 98 JDM engine (JDM 97-98 Subaru Forester SF5 EJ20G 2.0L Quad Cam Turbo Engine Impreza WRX EJ20). I need to verify correctly but in my case since it's a VW bus it's being blocked by the radiator and it's a pain to get out/in. I read about adding resistors to the line but not sure what to do.
Re: VW Bus EJ20T
I will add the MSQ later as I am not home at the moment.
Re: VW Bus EJ20T
Sounds like my motor 99-00 JDM EJ20 Turbo.....
It had this wheel (below) on it and then swapped it over.....
Re: VW Bus EJ20T
Where did you buy that crank trigger? Can't seem to find it on ebay or online. Do you have a link?
Re: VW Bus EJ20T
Did you confirm what crank trigger wheel you have right now ? I don't want ya buying something you already have.
Re: VW Bus EJ20T
The 36-2-2-2 Subaru STI crank trigger wheel part # is 13021AA141. It can be got from eBay or Amazon.
Re: VW Bus EJ20T
I installed the crank wheel and it is reading as expected. Problem I still have is the temperature sensor keeps reading 180F. I changed settings to Saab/Bosch and tried inverting the cables just to see but I can't get a reading.
Re: VW Bus EJ20T
Check to be sure the temperature sensor is grounded correctly.
Re: VW Bus EJ20T
You can't ground or leave the CLT sensor line open, the software will default to 180°.
Connect an appropriate fixed resistor from the CLT lead to ground to test.
Check sensor with an Ohm meter?
Re: VW Bus EJ20T
Ok so, everything was working fine. I took a break since Hurricane Maria hit Puerto Rico. Now when I come back to bus the crank sensor reads 0 rpm. I took the sensor out and checked cable and it works if I touch the sensor to crank wheel but not if I spin it around. Not sure if I changed some sensitivity settings or how can I test to fix this.
Re: VW Bus EJ20T
Can you post an MSQ.......I'll check to see if it's different than mine.......seeing as though we're running similar set ups.
Also......what kinda coil(s) are you running ?
Re: VW Bus EJ20T
Attached my msq! I'm a noob at this so feel free to make corrections.
- Attachments
- 2017-11-14_15.38.07.msq
- (118.82 KiB) Downloaded 29 times
Re: VW Bus EJ20T
I can now see crank pulses... not sure what my settings need to be for it to start properly. Mind sharing ur msq so I can analyze.
- Attachments
- Capture.PNG (102.81 KiB) Viewed 1375 times
Re: VW Bus EJ20T
PM sent with my email. I'll attach my MSQ later when I'm home. And if you're running a MAF I'm no help to you sorry
Questions for you below:
1) What kinda coil/coilpack(s) are you running in wasted spark?
2) What wiring diagram have you been using ?
3) Have you used the 'output test mode' for either the spark or the injectors?
Re: VW Bus EJ20T
Some of the differences I see are:
Mine: even fire , wideband , has KPA above 100 meaning it's a turbo ( I thought yours was also) and I have 'odd fire first angle" not set. (not sure what it is?)
Yours: odd fire , you have a narrow band , KPA only up to 100 for your tables , and you have 90 for your " odd fire first angle".
I'm no pro like the rest of the team on here so don't go and change anything until you're confident. I have no road time on these settings/tune BUT my combo does start easy and rev nicely in the driveway. Just been busy with other things.
Hoping others can chime in they see some differences that I've missed. Also like many others have said here before.......don't load in someone else's tune and expect good results. To many variables.
- Attachments
- 2017-10-09_19.36.51.msq
- (116.07 KiB) Downloaded 41 times
Re: VW Bus EJ20T
Hello Panel,
Thanks for posting your msq, will use it later when I get home. I have not moved my bus out of the garage. All those settings are pretty much incorrect. I am still in the process. I have a MAF sensor (still need to figure out how to calibrate it). ATM I am trying to get my narrowband o2 sensor to work it has 3 cables but I am unsure how to plug it. Tried playing around with one to sensor ground cable, one to 10amp current and one to the o2 cable but still get no reading. I am by no means a pro in this but I am crazy enough to play around with it. Still no electricity power where I live (because of hurricane Maria) so I am way behind on this project because of this. I appreciate your help whenever I get stuck with something trivial. Currently I just need all sensors to work and give accurate readings so I can move to the next phase (tunning).
Any help on how to wire the o2 or why it's not working would be helpful.
Re: VW Bus EJ20T
A wiring diagram from an EJ diagnosis manual will give you clues to the O2 wiring.
However you will not be able to tune with a narrowband O2 sensor, these are "high speed switching sensors".
They are designed to be used in an unbalanced system that constantly switches from rich to lean to maintain an "average" AFR.
These sensors do not deliver a linear output for O2 content, so the output from these sensors cannot be converted to AFR.
(If they could no one would use a wideband to tune...)
I can find no data that the EJ20 (there is no T model) is an odd fire motor, they sound funny because of the exhaust layout.
Given this you should not be using any of the odd fire settings.
The firmware I have open does not allow any odd fire settings in 36-2-2-2 mode (they are greyed out). Which firmware are you using?
A picture or link to the Crank wheel you are using might provide clues.
Since you are new to the game I would not try to use the MAF in the first go around.
I would tune it using Speed Density until your tuning confidence reaches a higher level.
