Strange die and restart issue with microsquirt
2008 Ducati hypermotard 1100s that is turbocharged
ms2extra 3.4.2 firmware
Bosch 0 227 100 211 ign module mounted to a piece of 1/4" aluminum under the tail, with decent airflow over it
Stock coils
Bosch ev14 HighZ injectors
I never had this issue before I swapped motors. During the time of swapping the motor I took the opportunity to clean up the harness and move from the two externally mounted BIP373s to a Bosch 211 ign module. I believe this has something to do with my issue.
My Issue:
Do a wot pull through all the gears and its fine, do another wot pull a minute later than the bike shuts down randomly. I can power cycle the ignition and bump start it back to life while I am still rolling and it seems to idle fine and free revs fine but as soon as I release the clutch and put some load on the motor it dies again. The only way to remedy this is to put the bike in neutral and start it like normal with the starter, it will then run fine.
The shut down almost seems like ignition driver overtemp shutdown. What puzzles me is the not wanting to run under a load until its been started with the starter motor....The ecu has no way of knowing I am bump starting or using the starter other than cranking speed....and even so, why would it care?
I have ruled out the Microsquirt module its self by trying a brand new unit on the bike with the same exact issue.
I had a resistor installed in each low level igntion output signal to the BIP373s previously, I believe they were 1kohm but cannot be certain. Its been so long since the install that I cant remember the exact reason.
Documentation shows I don't need any resistors for the Bosch 211 module. But I am somewhat questioning this now....
Datalogs don't seem to show anything out of the ordinary during shut down. I even dropped my dwell time about as far as I could without getting break up....this still didn't help.
I have attached my msq but the log is too big so here is a link to download it from my dropbox
https://www.dropbox.com/s/m011g07u48t0j ... s.msl?dl=0
at 425second-450second you can see a wot pull through the gears with no issues.
At 470second I begin another wot pull at which the motor dies at about 475seconds.
Thanks in advance everyone!
Stock coils
My Issue:
08 Ducati Hypermotard 1100S (1100cc oil cooled 90* Vtwin) + Microsquirt v3, sequential ignition & injection + td04h 15g
Re: Strange die and restart issue with microsquirt
i cant specifically see a reason for it cutting out in the log, but when you do try to restart it you do have a load of trouble syncing up with the rpm maybe have a look at the cam sensor and wiring
There are lots of Microsquirts having reset issues due to noise on the bootloader wire.
Have you tied the bootloader wire to TPS VREF (5V) ?
If not, give that a try. It's helped quite a few of us with weird reset issues.
Bringing this one back to life with another log and msq. Im really stumped as to why I have to power cycle the ecu AND crank to start the engine after the cut out. I see no reason for the ecu to not function properly if I just bump start the bike....
I just rode the bike with the wastegate pinned open, and ran it all the way to redline multiple times, without a single issue with cutting out. So that rules out crank/cam sensor, in my mind.
Then, with the wastegate hooked up, did a couple pulls, and the cut out issue is back. It most definitely ONLY HAPPENS UNDER HIGH LOAD, I think this is key to figuring out the issue.
Hybrid- I did try tying the bootloader wire to the tps 5v vref, but that didn't help.
Grom_e30 - part of the reason it through a bunch of errors when trying to start had to do with a bad battery and some backfires. But I did find some issues with the engine speed sensor wiring which I fixed and that definitely helped clean up alot of sync errors.
It needs a power cycle probably because something (noise) has corrupted the working memory.
The working memory can be altered while the motor is running TS does this for many of the changes but they are not saved until you burn them.
A power cycle reloads the working memory from the last saved (burn) iteration.
You should start by stepping through the Do's and Don'ts.
I would thoroughly check and verify each point one at a time.
A power cycle by its self does not fix the issue. Like I stated in my quote below, I have to actually crank over the motor with the starter in order to get the bike to run normal again. If I just power cycle then bump start it, it will idle fine, but as soon as any load is put on the motor, it will die.
All my wiring and grounds are by the book, I am very familiar with the issues that are caused by bad grounds and noise. I am just at the point where I have to start moving grounds, and separating wiring to eliminate noise, which I would prefer to not do, considering it is all correct.
The fact that I do not have this issue at all when the wastegate is open and there is no boost tells me that the root cause is from something that only happens in boost....Higher injector PW values causing noise? Ignition driver?
I fail to see why the ecu cares as to whether I crank the engine to start it, or whether I simply bump start the engine while rolling. All though this is not the root cause, it sure has me curious.I can power cycle the ignition and bump start it back to life while I am still rolling and it seems to idle fine and free revs fine but as soon as I release the clutch and put some load on the motor it dies again. The only way to remedy this is to put the bike in neutral and start it like normal with the starter, it will then run fine.
I figured out the strange reason for not being able to bump start the bike after an ecu power cycle....the stock ecu is still controlling the fuel pump, and its not allowing it to turn back on
So that leaves me still trying to figure out a normal resetting issue with the microsquirt. I started another thread to try and diagnose my sync loss issue at cranking, maybe it has something to do with...maybe not.
Just curious...... Why are you not controlling the FP with MS?
MS2 v3 w/extra 3.4.2 Release
TinyIOX from JBPerformance
Sometimes strange things occur on bikes. This winter I opted to replace some original stock circuits and ended up redoing everything. V2 Microsquirt on a 1983 antique bmw basically.mdlimy wrote:I figured out the strange reason for not being able to bump start the bike after an ecu power cycle....the stock ecu is still controlling the fuel pump, and its not allowing it to turn back on
Last years operation I thought was fine (I thought). First operation this year was a disaster with emf, failed ignition fuses and I managed to spike & kill my Inovate WB as well .
No problem, a pause to reflect/ reset, close overall review on technique and proximity of delicate runs to current laden ones (not an easy task on a fared bike) with relocation on a couple - and then an aggressive "shielding and drainage" campaign on pretty well everything. (I even re-shielded my 14point7 cable on the outside with - foil laid onto 1.5" wide cellotape, then cut into long 0.5" strips and wound around cable drained to frame and finished with a discreet fish net type sheathing for a normal look where visible).
The bike thereafter ran without emf issues but the tune was quite different and I've since pretty much started over recreating my VE tables, cranking and warm up values, and most likely timing again. Although I generally choose the difficult ways to do things - this last most likely an MS lesson I thought I had been schooled in (but hadn't).
1983 BMW R100RT Motorbike
Turbocharged - Water/Meth
Sequential Ignition & Fuel
"Perky Sleeper" that excites bike enthusiasts once discovered (or being passed)
Newest project - 1995 BMW K75 is V3 Microsquirt, "Turbocharger - Of Course"
The stock ecu is still in place to run the dash, and it happened to still run the fuel pump fine so I left it. Now after this issue, I will most likely switch it over to the microsquirts control.kjones6039 wrote:Just curious...... Why are you not controlling the FP with MS?
Very similar to my situation....The bike ran fine last summer. Over the winter I tore it all down and built a whole new harness, and cleaned up lots of odds and ends, which is when this issue began...it must be some sort of noise issue.R100RT wrote:Sometimes strange things occur on bikes. This winter I opted to replace some original stock circuits and ended up redoing everything. V2 Microsquirt on a 1983 antique bmw basically.mdlimy wrote:I figured out the strange reason for not being able to bump start the bike after an ecu power cycle....the stock ecu is still controlling the fuel pump, and its not allowing it to turn back on
Quick update to close out this thread....
Wired the fuel pump up to the uS and the issue has gone away. Turns out the stock ecu was shutting off the fuel pump randomly for some reason and I wasn't having any reset issues with the uS. Once uS took control of the pump everything has been great.
Just have to sort out the sync errors during cranking but I have a separate thread for that, so consider this solved....and nothing to do with the microsquirt at all
