MS2 v3.0 Relay Control JS11(PA0)
9alex16v
Post by 9alex16v »
Hi Guys!
I have a problem with the activation of the relay to control the fan of my car.
I'm using js11(pa0) with the output circuit
Relay pin:
87 - Positive Fan
30 - Positive Battery
86 - Megasquirt 2
85 - Positive Switch
But fan is always on
Re: MS2 v3.0 Relay Control JS11(PA0)
Post by racingmini_mtl »
9alex16v wrote:Relay pin:
87 - Positive Fan
86 - Megasquirt 2
Why are you not following the diagram you posted?
kjones6039
Post by kjones6039 »
87 - Positive Fan
86 - Megasquirt 2
That would explain it (always on, that is), alright!
MS2 v3 w/extra 3.4.2 Release
TinyIOX from JBPerformance
DaveEFI
Post by DaveEFI »
You need to decide if you are switching the positive or ground to the fan motor. That circuit shows the ground switched.
Personally, I don't like that circuit. I'd have a separate 12v with fuse for the high current fan motor. The 12v for the relay coil is low curent, and could come from the MS 12v side.
Rover SD1 3.5 EFI
MS2 V3
Tech Edge O2
London UK.
rickb794
Post by rickb794 »
You configure the output status by setting the "power on value" and the "active value".
