I wish this were the case but there are several different DIS units apparently. James may or may not confirm this,Six_Shooter wrote:I did have some scope shots at one point, I'll have to find them. However signals are the same for HEI7/8 as far as between the ICM and ECU are concerned.
However, I've been running this setup for a year or so, maybe longer now with the MS, though I have used the GM DIS for many years longer than that with GM ECMs.
My setup;
LX9 (3500), external crank trigger (7x), because the LX9 uses a 56x similar to some LS engines and didn't work with my GM OBD1 EFI setup, where I used the earlier 60 degree V6 ignition system (before switching to MS), that I have used on my old Franken60, my Nissan L28 and now my LX9. The only difference between the internal and external setups is that my sensor placement is adjustable, though I have it very close to where GM places it in relation to crank angle, MS2 3.4.2 (even though I have an MS3 for it, just not installed yet).
The settings as far as in Tuner Studio is concerned are identical to HEI7/8, except for the trigger angle. This must be higher than 50* to use same cylinder timing instead of next cylinder timing. Even the GM ECMs do this, and has to do with looking at one set of 3 notches while cranking and switching to a different set of 3 notches. Now one other change that I had to make was switching from standard dwell to fixed dwell of 50%. I found that standard dwell ended up with too high of a dwell period (or rather too high of a pulse width) and would drop spark at higher RPM and/or boost. I tried down to 30% or so, but found 50% to work best.
This ignition system was used bewteen 1987 and 2004 or so on FWD 60 degree V6s, including the 2.8, 3.1, 3100 and 3400, along with the 3.4L in the 1993 to 1995 F-body.
I have a document that is about 80% done that relates to the HEI and similar DIS units, but haven't had a chance to finish it up to be happy with posting it. If I can maybe I'll put some work on it later to get it up in the next couple of days.
Any problems that occur are not software settings issues, if you use standard HEI settings, except for the aforementioned changes, it will work. Any issues are likely related to hardware, be it bad CPS, poorly routed wiring, or misplaced/incorrect wiring, etc.
as there have been many people trying to work together to get it fully sorted out to work with MS and many have moved on to different things. There seem to be some variations to the input and outputs from both the ICMs and ECMs themselves, This coming from someone from GM who has worked with the DIS modules for the better part of 10 years IIRC. I won't name them unless they feel like poking thier head in to confirm.
At this point there is so much misinformation out there I choose to believe none of it until I get my O-scope and get mine working. It has been discussed that no two setups are alike, and thats why there has been such an issue getting all of the DIS units working with MS. What works for one does not work for another.
So until I get to probing mine and a donor vehicle to get these signals confirmed, I believe no one. Not saying anyone is wrong or that I'm trying to rub anyone the wrong way or be rude; Just saying that until I see it with my own two eyes, I won't believe it.
Six, feel free to post anything you may have here if you want, as there is no such thing as too much information. And if it turns out that all DIS units are truly Identical in respect to the 60*v6 engines then we can finally put this to bed and get confirmed information in the manuals
I truly do want us to work together as a community to get this done, So my apologies if any of that is taken the wrong way.
