VR Sensor Questions
R100RT
VR Sensor Questions
Post by R100RT »
Hi All - I'm planning/ tinkering on another BMW project, with an inline 3 cylinder K75 motorbike engine. A 36/1 tone wheel is easy to add, however for the cam sensor I'm looking at options still.
I will be using VR sensors again, had really good success even with my older V2 vintage MicroSquirt. A VR conditioner chip helped even things out for sequential operation, but on this engine the addition of the cam sensor is still a design in process at this point - with a wish to avoid too serious of modifications to the cam gear train and other internals. There are the cam lobes - anyone found a success utilizing the mass of the lobe to establish cam timing? (one tooth required)
Below is an image depicting both a cam lobe and an end plate with a single square tooth (on another application).
So, I'd like to try the cam lobe for simplicity - and can test but wondered at others experience?
Thoughts, comments welcomed.
Lorne
1983 BMW R100RT Motorbike
Turbocharged - Water/Meth
Sequential Ignition & Fuel
"Perky Sleeper" that excites bike enthusiasts once discovered (or being passed)
Newest project - 1995 BMW K75 is V3 Microsquirt, "Turbocharger - Of Course"
rickb794
Re: VR Sensor Questions
Post by rickb794 »
Cam sensor timing is not critical, it just needs to be within a certain window.
A valve lobe should work check the manual to see if it falls within the useable window.
A hole drilled in a gear or sprocket will work as well.
LAV1000
Post by LAV1000 »
Anyway to point it sideways to the lobe ?
Or make your own custom sensor whit a hallsensor like ATS627 Allegro.
Been using this on a mill, tooth/rpm counter, works nice.
Been thinking of using it on my bike to get full sequential, but have to ruin my valve cover for it :roll:
R100RT
Post by R100RT »
Yes, not wishing to alter the stock valve cover. I could organize a sensor at right angles to the cam lobe, or come at it from above - that was somewhat my question but I can certainly try some testing. I feel having anything partly or totally under a cover would create enough heat that a VR sensor would be the wise choice, but if there are Halls that can handle that then guess I need to get out more :lol:
LAV1000
Post by LAV1000 »
R100RT wrote: but if there are Halls that can handle that then guess I need to get out more :lol:
This has a max temp of 150 C :D
