Hi All - I'm planning/ tinkering on another BMW project, with an inline 3 cylinder K75 motorbike engine. A 36/1 tone wheel is easy to add, however for the cam sensor I'm looking at options still.
I will be using VR sensors again, had really good success even with my older V2 vintage MicroSquirt. A VR conditioner chip helped even things out for sequential operation, but on this engine the addition of the cam sensor is still a design in process at this point - with a wish to avoid too serious of modifications to the cam gear train and other internals. There are the cam lobes - anyone found a success utilizing the mass of the lobe to establish cam timing? (one tooth required)
Below is an image depicting both a cam lobe and an end plate with a single square tooth (on another application).
So, I'd like to try the cam lobe for simplicity - and can test but wondered at others experience?
Thoughts, comments welcomed.
Lorne
VR Sensor Questions
VR Sensor Questions
1983 BMW R100RT Motorbike
Turbocharged - Water/Meth
Sequential Ignition & Fuel
"Perky Sleeper" that excites bike enthusiasts once discovered (or being passed)
Newest project - 1995 BMW K75 is V3 Microsquirt, "Turbocharger - Of Course"
Re: VR Sensor Questions
Cam sensor timing is not critical, it just needs to be within a certain window.
A valve lobe should work check the manual to see if it falls within the useable window.
A hole drilled in a gear or sprocket will work as well.
Anyway to point it sideways to the lobe ?
Or make your own custom sensor whit a hallsensor like ATS627 Allegro.
Been using this on a mill, tooth/rpm counter, works nice.
Been thinking of using it on my bike to get full sequential, but have to ruin my valve cover for it
Yes, not wishing to alter the stock valve cover. I could organize a sensor at right angles to the cam lobe, or come at it from above - that was somewhat my question but I can certainly try some testing. I feel having anything partly or totally under a cover would create enough heat that a VR sensor would be the wise choice, but if there are Halls that can handle that then guess I need to get out more
This has a max temp of 150 CR100RT wrote: but if there are Halls that can handle that then guess I need to get out more
