Hi, I'm having problems when my engine loads more than 150kpa, makes an explosion through the exhaust and stops pushing ...
is a vw 1.6 8v turbo with injectors 330cc jetta 1.8t
If i do not charge more than 150kpa everything works perfectly
attachment datalog and msq ... my ecu is a MSEXTRA 3.57
thank you in advance, excuse my bad english
Problem on boost
Re: Problem on boost
You're both running out of injector and getting noise from the distributor pick-up.
Thanks!!! im going to get all resistive and change inyectores more bigsMatt Cramer wrote:You're both running out of injector and getting noise from the distributor pick-up.
