I have an ms2 working additional drivers mod.
I will install it on a 4cyl 8 injectors.
4 injectors on bank A
4 injectors on Bank B
I want to know how to configure ms2 to work:
Bank A - Semi Sequential + Staged Bank B Semi-sequential
or
Bank A Semi-sequential + Staged Bank B Batch.
Regards!!
Ms2 + add.Driver + Two bank + Semi-seq
Re: Ms2 + add.Driver + Two bank + Semi-seq
Any hint?
I'm stuck until figure out.
Your setup is confusing. You mention bank A and B but you also say that you have additional drivers. With additional drivers, you should have 4 injector channels: A, B, C, and D (or 1, 2, 3, and 4 according to the documentation). You would need to put 2 injectors per channels and the primary would be channels A and B and the secondary would be channels C and D. Channels A and C fire the same cylinders when staging is on and B and D are together.
If your firing order is 1-3-4-2, channels A and C are for cylinders 1 and 4 and channel B and D are for cylinders 2 and 3.
As for the settings, enable sequential/semi-sequential, enable the additional injector channels and enable staged injection. This will assign the injector channels as mentioned above. You also need to set the req. fuel settings to 2 squirts/simultaneous to get the correct req. fuel value.
