Bosch wide band O2 calibration numbers
What numbers have others used to infill the calibration values for a Bosch wide band O2 sensor?
Re: Bosch wide band O2 calibration numbers
Do you know that you cannot directly connect a wideband O2 sensor to the MS? You need a controller for that and then the controller is connected to the MS. The calibration values are dependent on which controller you choose.
I'm in the Tuner Studio MS v2.6.01. The EGO sensor in the AFR table does NOT have the Bosch wideband sensor listed. So at this time the EGO Sensor is blank w/ no values for Volts and AFR
Read my previous reply again.
Check out some of the wideband controllers. Megasqurit/Microsquirt can't read just the wideband sensor itself.ken-r-mer wrote:I'm in the Tuner Studio MS v2.6.01. The EGO sensor in the AFR table does NOT have the Bosch wideband sensor listed. So at this time the EGO Sensor is blank w/ no values for Volts and AFR
https://www.google.com/search?q=wideban ... 66&bih=612
1985 Dodge Omni GLH Turbo MicroSquirted 367whp http://www.msextra.com/forums/viewtopic ... 04&t=67324
That is because it is the make of wideband controller which determines the output voltage.ken-r-mer wrote:I'm in the Tuner Studio MS v2.6.01. The EGO sensor in the AFR table does NOT have the Bosch wideband sensor listed. So at this time the EGO Sensor is blank w/ no values for Volts and AFR
Rover SD1 3.5 EFI
MS2 V3
Tech Edge O2
London UK.
MS2 V3
Tech Edge O2
London UK.
