Parrallel Install
Parrallel Install
I'm about in wire up my MSII, but need to keep the oem pcm to control the trans. I plan to splice into the oem harness near to oem pcm. My question is. Can use (t into) the switched ignition from the oem pcm to power the MSII?
Re: Parrallel Install
Do you want spark control?
What kind of crank sensors do you have?
You can do fuel only off the coil negative...
Yes, I want fuel and spark control. I plan on getting a 36-1 trigger wheel. This is going on an 01 Dodge Dakota with a v6.
Power for the MS should come from a main power relay as shown in the manual.
page 14
page 14
