Parrallel Install
DBL.DWN
Parrallel Install
Post by DBL.DWN »
I'm about in wire up my MSII, but need to keep the oem pcm to control the trans. I plan to splice into the oem harness near to oem pcm. My question is. Can use (t into) the switched ignition from the oem pcm to power the MSII?
rickb794
Re: Parrallel Install
Post by rickb794 »
Do you want spark control?
What kind of crank sensors do you have?
You can do fuel only off the coil negative...
DBL.DWN
Post by DBL.DWN »
Yes, I want fuel and spark control. I plan on getting a 36-1 trigger wheel. This is going on an 01 Dodge Dakota with a v6.
rickb794
Post by rickb794 »
Power for the MS should come from a main power relay as shown in the manual.
page 14
