HC-06 bluetooth module and Microsquirt Module?
kim_gulle
Post by kim_gulle »
Hi!
Just have a quick question.
I am developing a mainboard for the microsquirt module and i want to incorporate the HC-06 bluetooth module onto the board. But is it possible to connect the TX and RX terminals of the HC-06 to TXOUT and RXOUT of the Microsquirt module?
The reason i'm wondering is that normally when i use the HC-06 with a regular megasquirt, i connect the HC-06 straight to the cpu. So would it even be possible to route it through the MAX3221 of the Microsquirt?
Kim
mazdaspeed
Re: HC-06 bluetooth module and Microsquirt Module?
Post by mazdaspeed »
My thoughts are you might have to run in through another 2nd max232 or max3221 to step it back down for the module
Sent from my SM-N920I using Tapatalk
kim_gulle
Post by kim_gulle »
I see, so basically connect it like the "isolated usb interface circuit"? Since the FT232RL is also designed to connect straight to an MCU?
Vauxi
Post by Vauxi »
I had to connect the HC05 straight to the Microsquirt Module TTL lines.
kjones6039
Post by kjones6039 »
kim_gulle wrote:I am developing a mainboard for the microsquirt module
Hmmmmm........ interesting..........
For what purpose, may I ask?
MS2 v3 w/extra 3.4.2 Release
TinyIOX from JBPerformance
