Hello,
I have a MicroSquirt V2.2 based ECU (it is the Generic Plug-n-Play unit that Stratified Tuning used to sell).
I would like to use DIYAutoTune's hall effect crank sensor with it; it has a built in pull-down resistor.
But, this is the extent of their instructions for my board: "older MicroSquirts will need to use the Hall effect input".
Does that mean that I should be connecting my signal wire from their crank sensor to OPTO-?
Thanks,
Jesse.
Wiring DIYAutoTune Crank Sensor on MicroSquirt v2.2
BMW M10 Engine in Datsun 520 Pickup
Re: Wiring DIYAutoTune Crank Sensor on MicroSquirt v2.2
Yes, connect it to Opto.
This is a simplified diagram of how I did mine:
http://www.msextra.com/forums/viewtopic ... 9&p=469271
