high RPM on cold start(solved)
gto66_455
Post by gto66_455 »
I am having a problem with my cold start. The first time I attempt to start my rpm's go to 2100 and my afr is 18. When I turn off the key and try the second time my rpm is still 2100 but the afr is 14 and the car will start. I think there is something wrong with the rpm reading during cranking, it seems to be ok while running
I have MS2 3.0 with 3.4.2 firmware
cranking_modified.msl
(124.48 KiB) Downloaded 26 times
tryingbe
Re: high RPM on cold start
Post by tryingbe »
Big V8.
What valve are you using for idle control?
What wideband are you using?
gto66_455
Post by gto66_455 »
455 pontiac
I have a four wire stepper.
AEM wide band
Post by Matt Cramer »
I see you're controlling ignition. What sort of distributor pick up are you using?
gto66_455
Post by gto66_455 »
It is a MSD ready to run distributor with three wires out, red power, orange signal and black ground. I believe it is a VR pick up. Also has a gray tach signal wire.
How exactly is that wired up?
rickb794
Post by rickb794 »
gto66_455 wrote:It is a MSD ready to run distributor with three wires out, red power, orange signal and black ground. I believe it is a VR pick up. Also has a gray tach signal wire.
If it is a powered sensor it is not likely a VR (unless the distributor has a high current coil driver built in).
gto66_455
Re: high RPM on cold start{solved}
Post by gto66_455 »
I figured out the problem. When I originally wired my relays I had only wired the fuel pump to the FP relay, and everything else to the other relay. In the manual it shows that the fuel pump, injectors, coil and o2 sensor get power from the fuel pump relay, the dist and ecu get power from the other relay. When I rewired the relays my cranking rpm was where it should be, about 200 rpm.
