timing fluctuates
timing fluctuates
I run a 36-1 wheel with a ford 2 wire VR sensor (microsquirt) and I fix the timing and it is steady at idle but drops of 10 degrees or so after 2k rpms when I rev it . The reluctor is reversed polarity set on falling edge . I had it on rising edge with the norm polarity and it ran the same. Any ideas? hardware latency doesn't help
Re: timing fluctuates
Post MSL and MSQ.
Re: timing fluctuates fixed
sorry just a wonky timing light
