EDIS tooth angle.
107merc
EDIS tooth angle.
Post by 107merc »
All the diagrams associated with setting up for EDIS show the teeth on the wheel cut at an angle on both sides.
Mine are cut square. Will this make a difference on getting a good signal?? Thanks.
rickb794
Re: EDIS tooth angle.
Post by rickb794 »
That looks fine, just make sure it is well centered.
Tooth 1 position is critical for use with a EDIS module, that determines the base spark timing.
However, I recommend not using the EDIS module unless you have to.
107merc
Post by 107merc »
rickb794 wrote:That looks fine, just make sure it is well centered.
Any special reason you wouldn't go EDIS?? We don't plan to go beyond wasted spark and batch injection
with this engine.
Thanks.
rickb794
Post by rickb794 »
When you use the EDIS module you can't use spark cut, rev limiting, launch control and flat shifting may also be affected.
Spark retard will work but no less than 10° which is the base timing for the EDIS
107merc
Post by 107merc »
Thanks.
rickb794 wrote:Spark retard will work but no less than 10° which is the base timing for the EDIS
EDIS supports -10 deg (10ATDC)
rickb794
Post by rickb794 »
Ah, thanks I was confusing with TFI?
