EDIS tooth angle.
EDIS tooth angle.
Mine are cut square. Will this make a difference on getting a good signal?? Thanks.
Re: EDIS tooth angle.
That looks fine, just make sure it is well centered.
Tooth 1 position is critical for use with a EDIS module, that determines the base spark timing.
However, I recommend not using the EDIS module unless you have to.
Any special reason you wouldn't go EDIS?? We don't plan to go beyond wasted spark and batch injectionrickb794 wrote:That looks fine, just make sure it is well centered.
with this engine.
Thanks.
When you use the EDIS module you can't use spark cut, rev limiting, launch control and flat shifting may also be affected.
Spark retard will work but no less than 10° which is the base timing for the EDIS
Thanks.
EDIS supports -10 deg (10ATDC)rickb794 wrote:Spark retard will work but no less than 10° which is the base timing for the EDIS
Ah, thanks I was confusing with TFI?jsmcortina wrote:EDIS supports -10 deg (10ATDC)rickb794 wrote:Spark retard will work but no less than 10° which is the base timing for the EDIS
