Do I have a decent trigger?
So today I got some feedback from the VR crank sensor on my Beetle, wired the sensor to pins 1+ 24 with the shielding connected to pin 2 (all soldered)
MS2 V3.0 Extra code 3.2.1
36-1
Tach input set to 'Basic Trigger' although I have tried 'Toothed Wheel' too.
r52 and r56 wound fully anti clockwise
Connected to the laptop it was showing ~18000rpm at idle
Tweaked r56 until defined teeth are shown in tooth log and composite log and I think I cleaned it up with r52. Nice and steady but only showing 460 rpm or so (1/2) what it should be.
I think I've attached a log... first timer Does it look like I have a usable trigger at that? any reason why I am seeing 1/2 rpm?
Thanks for your time guys
36-1
Re: Do I have a decent trigger?
set it to missing tooth wheel if its a 36-1. log looks ok btw
So
Basic Setup > Ignition options > Spark mode (dizzy, EDIS, wheel)?
'Missing Tooth' isn't an option in there...
Thanks for looking at the file
spark mode = toothed wheel
trigger wheel arrangement= single wheel missing tooth
trigger wheel teeth=36
missing teeth=1
wheel speed = crank or cam depending on setup
the rest of the settings will depend specifically on your spark hardware eg no of coils spark output used and the tooth #1 angle ect
missing teeth=1
Ah got ya.
So I set it up as you say... Idle is still 18k rpm or something daft...
Oddly, when I did a little RPM sweep up to maybe 4k and back down at one point it did start reading about what I would have expected... I saw 3xxx rpm flash up which makes me think it's nearly right
I have attached a few more logs, if you could have a quick look that'd be awesome
I updated the firmware... Just to rule out anything there... now running 3.4.2 and guess what...
Trigger is working perfect
I only ran it up to 4000 RPM or so as it scares me a bit going higher than that
But looking good... Now onto the next mystery tour.
Thanks again for your input Grom.
you appear to be triggering off the wrong edge rising/falling, in the tooth logs you can see this by the long tooth having a longish tooth next to it. switch the edge and it should get rid of the longish bar
Ah ok good spot... It is likely seeing as I did flip that option at least once
Wired the coil in.
Fords edis coil (minus the EDIS)
Left wire to Spark A (IGN which is pin 37)
Middle wire to switched live from the standard coil
Right wire to Spark B (IAC2B which is pin 31)
With the engine running still on the distributor but the new coil wired in I got sparks on all 4 plugs... Ms doing what it should so far. So I slipped the ht leads off the ford coil onto the engine and tried to start it up.
When cranking though I have no tach input. I dropped cranking rpm down to 500rpm (from 650) but still nothing.
I have called it at that, getting dark here and the battery is probably a little tired.
Any ideas why I am missing the trigger when cranking? Is that a matter of fiddling with the trigger/hysteresis pots again?
Cheers.
Wired the coil in.
Cheers.
may well be a case of adjusting the pots, usually cranking it is harder to see the vr signal especially at a lower engine speed.
have you got the correct tooth #1 angle set? if this is not correct you will get the spark happening at the wrong time
Well that's something I've just been scratching my head over...
I put a black mark on the pulley around 5 o'clock where the missing tooth is. The Sensor is at 90º 3 o'clock
If the sensor was at tdc the offset would be ~130º. With the sensor being 90º ATDC I think the offset should be 40º
if you set the engine at tdc and count the gaps....
http://www.msextra.com/doc/pdf/html/MS2 ... 4-125.html
http://www.msextra.com/doc/pdf/html/MS2 ... 4-126.html
explains it
explains it
OK so I have tried 230º and 320º... No joy. It's back fired once or twice...
I think my problem is still trigger offset... With the pulley at TDC it has to rotate 230° before it sees tooth #1
Or 90º as the sensor isn't at TDC
Have I got that wrong?
if that pick is with the engine at tdc with clock wise crank rotation and each red line represents a tooth on the trigger wheel sensor is over the 5th tooth so that would make the tooth #1 in the region of 40 or so degrees
To me that pic looks like it should be rotated 90° clock wise so as not to confuse anyone......I don't think that's TDC.
In the one pic you said the sensor is at 90º 3 o'clock.......but in the other pic you have it as 12 o'clock.
'65 VW Bus with a Subaru EJ20 Turbo conversion , Air to water I/C , LS coils , 14Point7 Spartan 2 & Solid Air Fuel Ratio 52mm gauge.
MS2 Extra V3.0 board
Don't worry about where the pulley is in relation to that engine block... Its the only head on photo I have...
With the engine and pulley at tdc the sensor is at 3 o'clock
40° OK so I went the wrong way... I'll try it
No joy at 40º...
if you can still run the engine with the dizy you could then set the ecu to fixed timing 0btdc and run the engine and use a timing light on the ecu controlled no1 plug lead to check the tooth #1 tdc mark should line up with strobe light if its correct.
is it still having trouble syncing up when cranking??
edit: post a copy of the current tune so we can see what your working with here
It lives
Someone on another forum has the same trigger wheel as me... They have theirs set at 52º, I went out and tried that with no joy... I got the engine running again on the distributor and checked timing against my Ford coil... Found No1, no 2 etc and paired them up
1...4
3...2
plug
And hey presto...
Grom, that bar I was getting before the missing tooth... Turns out I had the sensor wired backwards. I changed rising/falling edge and lost the trigger, changed polarity of the sensor and bingo- cleaner trigger
1...4
3...2
plug
And hey presto...
nice one. now it runs you should use the strobe light out and dial in the tooth #1 to make sure the spark timing is correct
changing from rising / falling should have the same effect as switching the sensor wires btw
