flat afr and rpm drop in log file
erlend
Re: flat afr and rpm drop in log file
Post by erlend »
That’s between cable vr+ and cable vr- I meant.
Just to confirm my suspicion towards the faulty afr readings, I’ve attached a image ive found on line.
Is this the way the afr curve is supposed to look?
Screenshot of a working afr curve?
rickb794
Post by rickb794 »
Difficult to analyze a picture, but that looks ok.
