The VR sensor in EDIS sends a signal to the controller which in turn sends a +12V S/W
signal to the ECU. Does adjusting R52 and R56 actually have any affect on that signal??
Just curious. Thanks.
Another EDIS question.
Re: Another EDIS question.
If using the current recommendation, the VR input, yes (the older way was to use the opto input) you my well have to adjust R56. R52 is to reduce noise if present, which is more unlikely.
Thanks.
