Correct jumpers to use
91EVO
Post by 91EVO »
My engine 383 Tune Port injected with a Procharger supercharger running for 10 years on a modified Cyclone/typhoon ECM
I have been reading everything I can find for the last two weeks on setting up my system jumper wise. Just when I think I have it figured out I come across an different article saying do it this way. Here is my system, I built my Megasquirt 2 with a V3.0 board running Extra 3.4.2 and using the Megasquirt relay board, I have a stock GM HEI8 Distributor with R pin on control module to tach on R/B, G pin to R/B ground and I'm going to try B pin straight to vref without a relay to disable timing control and White wire from MSD 6AL to pin s5 .
My jumpers are - D14 to IGN
JS9 to S12C
all 4 IAC
XG1 to XG2 ?
TSEL to OPTDOUT ?
OPTOIN to TACHSELECT ?
Re: Correct jumpers to use
HEI ignition wiring is covered here:
http://www.msextra.com/doc/pdf/html/MS2 ... 4-109.html
rickb794
Post by rickb794 »
and MSD wiring is covered here in the manual,
5.3.5 CDI modules (e.g. MSD, Crane etc.)
You can use the HEI as just a source as long as it is locked.
ChevelleFan
Post by ChevelleFan »
I run a very similar setup. However, I'm wired a little differently. S5 goes to pin E on the HEI8 module. The - wire on the module goes to the white wire of the MSD. I have B tied directly into TPS Vref, same as you describe. Been working reliably for years.
-Dave
'70 Chevelle ZZ383/700r4/3.73 MS3X, 36-1, LS Coils, Holley Stealthram -- success story
'92 Saturn 1.9 DOHC/5sp, MS3, Champcar racer success story
'79 Malibu DartSHP400/80mm/PG/3.55, MS3X/36-1/LS Coils -- success story
Porsche 944 S2 3.0 -- MS3X/36-1/LS Coils, 1:44s Mid-Ohio, Pro Course
