data logger? (not on a laptop)
Blue 12
Post by Blue 12 »
has anyone made a cheap logger out of a micro controller like an arduino? power sports application, no room for a laptop. for ms2 or microsquirt? (or just for a few sensors on a non ms based setup ie where a ms is a piggy back)
2000 ZX-12R LSR turbo Worlds Fastest at 266.5MPH on board video here https://www.youtube.com/watch?v=CruXgKKzBUs
ol boy
Re: data logger? (not on a laptop)
Post by ol boy »
Yep, used a teensy3.2 and a 3.3v CAN tranceiver to a uSDcard adapter. The code is well sorted.
turbo conversion
Post by turbo conversion »
Nice video :D
David
LAV1000
Post by LAV1000 »
prof315
Post by prof315 »
Bluetooth dongle and an old android phone with shadow dash on it works pretty well.
Support the developers!
Suprazz
Post by Suprazz »
Yes you can use this: http://perfecttuning.net/en/accessories ... results=16
with MSDroid application or Shadow dash ms or Real dash
Or wifi to serial adapter like this one with realdash on iphone/ipad http://perfecttuning.net/en/accessories ... &results=7
Roleyrev
Post by Roleyrev »
I use this on my bike:
It runs on a 4D systems LCD display. It logs to an uSD card on the display.
I tried shadow dash with a BT dongle but didn't like the mucking around try to connect ETC.
The LCD boots in under a second and is basically ready to go when you turn the key.
racingmini_mtl
Post by racingmini_mtl »
Sorry for the OT but how does this 4D display look in the sun?
Manu
Post by Manu »
you also can consider CAN Converter Data Acquisition System :
http://www.msextra.com/forums/viewtopic ... 33&t=67858
Cheers,
Manu
I can supply, repair or upgrade Megasquirts in FRANCE.
https://www.megasquirt.fr
Roleyrev
Post by Roleyrev »
racingmini_mtl wrote:Sorry for the OT but how does this 4D display look in the sun?
Not Great. I have an OLED display one as well that holds up way better in the sun. I have to say I really only use it for logging. There are too many idiots on the road for full time fiddling.
Cheers
John
Blue 12
Post by Blue 12 »
ol boy wrote:Yep, used a teensy3.2 and a 3.3v CAN tranceiver to a uSDcard adapter. The code is well sorted.
I would like to know more about this, are you interested in building a few for $$?
ol boy
Post by ol boy »
Let me crunch some numbers and get back to you. Im thinking of an open source expansion board with some code examples for measuring speed, CAN adc, CAN pwm, water injection using MAPxRPM, ect. Anyone can down load the teensyuino ide and start smashing some C++ code. I also have a 12 bit baro sensor working over I2C which then sends a 10 bit adc to the ms for a baro value.
