Hi! im having issues with launch control retard. Its set -25º but, its only goes to 16º??..
Someones know the problem?
thanks!!
Launch control dont retarding
- Attachments
- no carga.msl
- (224.18 KiB) Downloaded 13 times
- msq golcito.msq
- (90.56 KiB) Downloaded 20 times
Re: Launch control dont retarding
The way your tach input is setup, with a trigger at 15BTDC you won't ever get advance less that 16 degrees. That's how it works. Please see this page in the manual and pages before and after.
http://www.msextra.com/doc/pdf/html/MS2 ... 4-104.html
Got it! So i Will configure like the manual says, going to 60btdc at trigger wizard and sincronize again the timing with the distributor! Thanks!jsmcortina wrote:The way your tach input is setup, with a trigger at 15BTDC you won't ever get advance less that 16 degrees. That's how it works. Please see this page in the manual and pages before and after.
Enviado desde mi MotoE2(4G-LTE) mediante Tapatalk
