2 step sometimes work, some doesn't.
tryingbe
Post by tryingbe »
So, I have a strange issue, sometimes the 2 steps works great, ie, I can rev the engine to 7k, step on clutch, rev drops while I still WOT.
Other times, the 2 steps rev limit seems to activate without the clutch switch input while I am still WOT, the log reflect this.
Looking for ideas. Thanks.
2017-12-27_15.52.05.msq
(119.95 KiB) Downloaded 20 times
2stepworking.msl
(89.74 KiB) Downloaded 21 times
2step not working.msl
(72.63 KiB) Downloaded 20 times
LAV1000
Re: 2 step sometimes work, some doesn't.
Post by LAV1000 »
Maybe use a pull up/down resistor set up on the clutch input ?
This way the input doesn't float when not active.
Post by Matt Cramer »
The log definitely shows the clutch switch input triggering on the "not working" log - see ADC7 drop at about the same time it applies the 2 step.
