Nissan Micra CG10DE Trigger problem
Hello!
Has anyone encounter this kind of CAS pattern. I really need to know what kind of wheel decoder must i use with this.
I have attached an image.
Is it even possible to work with this type of trigger/distributor?
- Attachments
- cg10de distributor
- 26803376_10212989354382748_1895842937_n.jpg (62.99 KiB) Viewed 508 times
Re: Nissan Micra CG10DE Trigger problem
I may be wrong, but I can't find any info showing that wheel pattern is supported, even on MS3.
Is there anther distributor that fits? Or can you crank trigger it?
The alternative is to modify that shutter to be a "basic trigger" (4 windows)
That would be a '4+1' wheel pattern and as far as I know there is no support for that type of pattern.
Seems that i must go with trigger wheel attached to the crank pulley with normal patter 60-2.
A 36-1 pattern would be favorable as the frequency on a 60 tooth wheel bumps up against the upper limit at high RPM.
I'll do that...thanks
If you're not going to rev the dog doo out of it a 60 tooth will work, in that case use what's handy.
