Hi.
The stock temperature gauge in my car is wired through the stock ECU. Now that this has been replaced by a Microsquirt V3 the temperature gauge won't work. Does anybody know if I can piggy back from the coolant temp sender to get it working again. The car is a Corvette LT1. TIA
Stock Temperatur Gauge
Re: Stock Temperatur Gauge
Your temp gauge should work off of the sender in the cylinder head and the MS off the one on the front of the engine. Did you redo your engine harness when you installed thr MS?
