Hi guys,
I am searching a part number for the VAG coils with high resistance (1k OHM). There is a lot of them and I don't know, which coils to choose. I don't want to build an buffer circuit...I wanna keep it simple
Thanks for helping
What VAG coils to use in my build
Re: What VAG coils to use in my build
The only readily available 1k vag style coil is the 4 pin Hitachi brand coils.
And do you have the part number? It would be great
Why not use one of the MANY Denso coils available? Toyota and Honda both have multiple varieties that all work well with both the standard and TC4477 methods of logic triggering.
Support the developers!
I used VW/Audio 06B905115E found them on ebay. Work without amp or buffer.prof315 wrote:Why not use one of the MANY Denso coils available? Toyota and Honda both have multiple varieties that all work well with both the standard and TC4477 methods of logic triggering.
Sent from my SAMSUNG-SM-G870A using Tapatalk
Thank you very much Peter6000! I was looking for that kind of information.
