MS II constant Ground/Power to pin36
MS II daughter board pin 17 has a constant 4.8v to it and 0.54v to pin 36 on db37
it will not fire the coil.
Will not pulse during spark test injectors work fine
if slaved in to running car get tach/rpm map tps and all other reading in Mstune
DIY MS II V3.0
DIY MS II V3.0
'86 944 Porsche na DiyAuto tune MS III V3.0 board
Re: MS II constant Ground/Power to pin36
How exactly is the board modified for spark output?
VR tach in
BIP373 direct coil driver of D14 with the resistor of D14
Make sure the metal tab on the BIP373 isn't shorted to the heat sink. Note that heat sink compound is slightly conductive, so if it gets around the mica insulator, it can cause a short.
I will pull it up n check it out..Matt Cramer wrote:Make sure the metal tab on the BIP373 isn't shorted to the heat sink. Note that heat sink compound is slightly conductive, so if it gets around the mica insulator, it can cause a short.
Also verify the IGBT jumper has been removed since you are triggering via a D14 mod.
That was it the insulator had a tear in it....Matt Cramer wrote:Make sure the metal tab on the BIP373 isn't shorted to the heat sink. Note that heat sink compound is slightly conductive, so if it gets around the mica insulator, it can cause a short.
seems like I fix one problem and another pops up....
the default calibration no longer work ie Map Bat voltage and temp sensors is The HC9S12C64 Processor going bad???
