Does the MS control coil negative ??
Re: Does the MS control coil negative ??
To Rich, about the capacitors, that picture was taken to send to PFTuning, who replaced the caps and redid the runs. Prior to that the MSSquirt was dead and was only in limp in mode. If you could build one and have the proper cable connector adapter a lot of rialta owners would be knocking on your door.
Other rialta owners said they were not willing to rewire anything and would just pay 1k plus for a refurbed VW one. Plug and play. Oscar
Oscar, have you checked the bottom of the unit for a serial number?
You can tell by the pics this is a non oem coil (gm style connectors).
yeah that's a first gen GM Vortec V6/V8 coil and ignition module (with some really UGLY wiring )Paul_VR6 wrote: You can tell by the pics this is a non oem coil (gm style connectors).
Support the developers!
Well i could cut the cable going to the old igniter, lose the brown ground and go straight to this coil i got a few days ago it is from Herko labled B024.
Here is the website link.
https://www.ebay.com/itm/Herko-B024-Ign ... Ie&vxp=mtr
oscar
oscar
TO Paul Vr6
Nothing on outside of case, new pics from today. I have a solid 5vdc on the triggerwire for coil from the squirt. Does not move regardless of hall effect sensor and when cranking. Very dim and fast blinking lites on the front of mssquirt when I turn the key on. Oscar
- Attachments
- MSsquirt 2 2 10 2018.jpg (454.11 KiB) Viewed 1279 times
- MSSquirt 2 10 2018.jpg (74.71 KiB) Viewed 1279 times
One thing to make sure if you reloaded a default msq is that you have spark on d14 (not js10) and that the ignition output edge is correct (use the tooltip for advise) you are using led with a coil with ignition amp not direct fire.
Also make sure nothing from the coil other than the trigger, power and ground. That 4th wire seems suspect.
Sorry Paul I need your beginner class, but where would i get a default msq, and would that prevent the lights from being on on the m/b? I thought of power, but I can t/s the relay all is good and I can also feel it clik when key is turned on. I also have 5 volts on the trigger, (coil connector removed and probing front part of connector. So I am pretty sure the ms is ok, and maybe the tune I had previously got corrupted. On the top of my laptop screen is says: Tuner Studio MS lite v 3.0.28-First Try 12 262017 (MS2/Extra release 3.2.4.20120901 22:00BST (c)KC/JSM?JB MS2) EFI Simplified
I know that First Try is my msq, should this be a default tune?
Your help is greatly appreciated. Oscar
Probably easiest to host the msq and I can take a look. I wasn’t sure if you were using the tune that came with the camper or you had loaded something else.
If d14 is selected for spark it changes how the led closest to the serial connector behaves.
It is included within the firmware zipfile. You can get that from the 'Downloads' link above.summerlint51 wrote:where would i get a default msq
Don't you get a new (default) MSQ when you open a new project in TS?
You would then use the TS msq and overwrite the ECU msq when you connect to the ECU?
Nope... you still have to manually Load a Tune.rickb794 wrote:Don't you get a new (default) MSQ when you open a new project in TS?
You could of course start from Scratch and Load the Default Tune from the Firmware Update folder. You can then Import the old Tables.
Summerlint51: You should probably update your Firmware to the Latest version. 3.4.2. You are on a fairly old Firmware. 3.2.4 is shown in header. Quite a few bug fixes and improvements since that version.
Sorry my luck when trying to do suggested things now laptop will not communicate with controller. Only a microsecond blink of lights on me when I turn key to on. Windows and portcheck find the USB on laptop but won't connect to ms. Jeez I am so tired of this, if it wasn't raining here (Jacksonville) I would cut the grass.
You have to make sure that the Com settings ( Properties ) for your USB port are the same in TS and in Windows Device Manager. Makes sure the Baud rates are set to the same inn Both. For a USB ports the Port should be 115,200 Baud . There is a FAQ on the Port settings.summerlint51 wrote:Sorry my luck when trying to do suggested things now laptop will not communicate with controller. Only a microsecond blink of lights on me when I turn key to on. Windows and portcheck find the USB on laptop but won't connect to ms. Jeez I am so tired of this, if it wasn't raining here (Jacksonville) I would cut the grass.
BTW, always try and Use the same USB port. Changing Ports sometimes results in the wrong Default setting in Windows .
You may be bumping up against an issue I have seen with Tuner Studio, if you disconnect the USB TS will not re-establish the connection.
I would have to restart TS to reconnect.
If anyone remembers me and this post I am back and still without the rv running. I sent out the ms2 for repair again and they replaced another diode somewhere. So i am back to square one. coil still not firing i have the 5vdc reference voltage to the hall effect and it does ground out when cranked but no change on the center of the coil wire, it just stays 5 vdc wihtout change while cranking. As all that replied told me that the ms is the only thing in between so hopefully we can start anew.
I am attaching the msq file,
thank you so much
Oscar
thank you so much
Oscar
- Attachments
- 2019-04-13_20.41.38.msq
- (117.75 KiB) Downloaded 38 times
If I may allow me to reiterate the basic of my VW.
1996 VW 2.5l Eurovan, 5cyl, fuel injectors, normal old style distributor, NO cop, in distributor is hall effect sensors that applies a grd to the msextra,,which then sends a ground to the coil, which then fires the coil to the rotor on to the plugs.
My problem that i am not seeing the change at the coil, the distributor changes when the hall effect window opens and closes.
For reference here are the voltages i have taken.
At the hall effect connector
NO power (key off) MS unplugged all connections are zero.
Key on, MS disconnected. negative reads .03vdc, ecm control 0vdc, positive .03vdc
Key on MS connected . negative reads .27vdc, ecm control 4.35vdc, positive 5.15vdc
When fully connected and hall effect rotating the ecm control 4.35 vdc goes to zero, then back up to 4.35 (eliminating distributor as a cause.
At the three pin connector at the coil.
Key on, ms disconnected. negative reads .02vdc, ecm control wire 0vdc, positive 12.45
Key on MS connected . negative reads .0vdc, ecm control 5.14vdc, positive 12.45vdc
When fully connected and hall effect rotating the 5.14vdc never changes in value.
One other thing is i took the coil wire and put it close to the ground and when I turned the ignition switch on it did fire but only once, never with the engine rotating. Copying exovcds techniques on youtube VW T4 2.5L No start / no spark
Would you think this is a ms extra programming error?
Thank you, Oscar
Thank you, Oscar
Do you have a 36-1 wheel in your distributor?
A 5 cylinder engine requires a cam trigger because the ECU cannot deal with 2.5 ignition events per rev. You need to fix that.
ty for replys, i believe the default tune had the spark mode set at edis, should i change it to basic trigger. I found this explaing it. https://speeduino.com/wiki/index.php/Basic_Distributor would setting it to basic triggerthen allow the coil to fire?
Basic trigger will work with a 5 cylinder engine with a distributor as long as you do have a basic trigger signal (5 equally spaced pulses at cam speed, in your case).
