having trouble to set correct trigger angle , use Microsquirt V3 with tuner studio V3.0.28 on multipoint 4 cilinder 8 valve E16SE opel/vauxhall engine
distributor is a 4 window hall from opel C16SE, bosch 0227100124 module as ignitor wired up to Microsquirt V3
i did check pulse from hall and it is on TDC, can i set ingnition to 10 degrees fixed timing and leave trigger anle at 0 ? and check later on with timinglight
have to fix TPS and MAP this weekend to let the engine running, but need some info for trigger angle
any help is welcome ,
thanks, and greetings from the Netherlands
Microsquirt with Hall distributor and Bosch 124 module
Re: Microsquirt with Hall distributor and Bosch 124 module
Please read section 6.2 of the hardware manual.
Including 6.2.1.1 Input phasing
http://www.msextra.com/doc/pdf/Microsqu ... re-3.4.pdf
