I´ve searched but havent found.... When I want to use PT6 and PT7 outputs then I always have to connect something to IACENBL pin? what does it needs? ground, +5 or +12?
I think it´s not +12 and I think I´m mistaken something but I´ve some experience with ms2 what needed wire wetween 12v and some pin to get IAC outputs working.
Thanks A lot
What to do with IACENBL pin? (micro module)
Re: What to do with IACENBL pin? (micro module)
It is an output, leave it open.
If you connect 12V to it you'll destroy the processor for sure.
thanks But is it useable somehow too for something?
I´m installing micro on a subaru and client wants to get as much extras as possible and I´ve already out of them I think.....sequential spark, boost cntrol, idle, tach, tank solenoid, launch, fan, flex etc
If you want more I/O you can add an IOX box and connect it to CAN.
It has no selectable function in the code. If you want it to do something, you'll have to write it into the code, then compile.
