1uzfe wiring
Tjohnson
1uzfe wiring
Post by Tjohnson »
Hey all.
I am wiring up my 93 1uzfe to run with stock ignition setup, but I have a question. I am hoping to use the stock coil ignitors. But I am confused on the wiring for them. And wiring diagrams I've seen show "IGT" and "IGF" going to the stock ecu.
I found one forum post that says "IGT" is output and "IGF" is "confirm fire
I know the ignitors are bonded to ground through their case, so is one wire the trigger and one sensor ground?
Sent from my Pixel 2 using Tapatalk
rickb794
Re: 1uzfe wiring
Post by rickb794 »
The knowledge in this forum doesn't always narrow down to a specific year and model.
Also models and equipment change depending on country of origin.
It is best to post a part # and picture of the ignitor/coil you have a question about.
You can also google the part # and sometimes you can find info about the part that way.
You might also check at DIYAutotune or in a forum that specializes in that particular motor.
prof315
Re: 1uzfe wiring
Post by prof315 »
Hook a logic level trigger to IGT on each ignitor. IGF can go to the sensor ground or be ignored.
Support the developers!
Tjohnson
Re: 1uzfe wiring
Post by Tjohnson »
prof315 wrote:Hook a logic level trigger to IGT on each ignitor. IGF can go to the sensor ground or be ignored.
Umjamlam
Re: 1uzfe wiring
Post by Umjamlam »
What is a logic level trigger? I am also in the process of connecting a megasquirt ECU to my 1UZ and the last thing I need to do is figure out how to connect my ignitors to the MS wiring harness.
1993 lexus sc400
Using megasquirt 3.0/3.57 with generic megasquirt harness
Re: 1uzfe wiring
Post by Matt Cramer »
Umjamlam wrote:What is a logic level trigger?
These take a low current, 5 volt signal. See the mods in section 5.3.1.3 or 5.3.1.4 of your board's MS2/Extra Hardware Manual for what you'll need.
