hello everyone im new to this.
i need help with a 2002 Mazda protege5 fs-de. i got the coil pack from a 2002 626 with the quad spark, but i dont have spark on the ignition setup spark mode i have as edis.
Everything is connected right. i need help starting it or if someone has a base map i could use.
I need help micro on a mazda fs-de motor
Re: I need help micro on a mazda fs-de motor
Do you get an rpm indication in Tuner Studio?
Hi rickb794,rickb794 wrote:Do you get an rpm indication in Tuner Studio?
The rpm move when I crank it over. But the tach wire is not connected could that be the problem.
Plus is my first to.e trying to tune a car. Any advice could help.
And thank you
