24-1 with second trigger ?
Will the jim stim simulate a 24-1 crank with a single trigger on the cam as a second trigger? If not how would one go about setting it up to work ?
There isn't an existing mode for 24-1 on the crank and a single cam trigger. But is that what you really mean?
If you want 24 teeth non-missing on the crank and 1 tooth on the cam then yes - it is called "LS1"
Yeah its 24-1 on the crank i looked last night just to make sure as i thought i might be wrong. And it has a single second single trigger on the cam.
This is for a Motorcycle engine. I aslo have a 8 tooth flywheel for the same motor but i what to setup whatever is the best trigger wheel setup for the motor i have plenty of time to setup either one i just want the one that will be the most accurate timming wise .
Im also going to be running the MS2 Extra code and COP set not WS
Thanks for any help im all ears.LOL
