Stim issues MS1 V2.2 PMP, IGN, IDL
D19 does not light when hooked up to the stimulator, also IGN, PMP,IDL LED on stim dont light either. I get good movement in megatune but stim LED's arent on. It is a V2.2 board 029y code that has been modded for boost control and spark. could it be Q3 and Q5. I just built a nearly identical board without boost control and everything on it is fine. Where should I start
All grown up and playing with toys!
Re: Stim issues MS1 V2.2 PMP, IGN, IDL
Could you post your MSQ? What gauges are reading correctly in MegaTune?
Matt,
This is going to sound stupid but I have no idea how to post msq's, also both of the boards are not in vehicles and have only been "tested" with the stimulator. All gauges on megatune are working, and respond to the movements of the stimulator pots it is just that the LED's on the stimulator on both boards are behaving differently. On my board w/boost control only INJ1 and INJ2 are on(when they should be) no PMP, IDL,or IGN also when moving TPS pot the PWM in megatune changes. If this helps. The other board I just completed works as it should. How to post msq's would be nice, any pointers would be greatly appreciated
Thanks!
Thanks!
Right below where it says Save - Preview - Submit, there's a tab marked "Upload attachment." Click that, click Browse, and select the file, then click "Add the file" and post.
Matt,
You have PM
Please feel free to PM me with any instructions or tips
You have PM
