Peter,
If you get something different, please post what you got. Also, you could try downloading the executable and wheel pattern files again to make sure they are correct.
The output above was obtained from what is currently on the web site (I downloaded the exe and jsw files just before running it and posting here). This was run on Win7 but it gives the exact same thing on XP. And you need to open a command window, go to the directory where the files are and type the command line. You probably already know this but I just wanted to make sure.
New JimStim firmware V2.0
Re: New JimStim firmware V2.0
Jean,
I had two different problems:
1) the wheel_converter.exe I built was bad. Not sure why.
2) I had forgotten that one only needed cygwin to compile the code. I was trying to run the exe file in cygwin. Your last post reminded me.
Both self-inflicted problems, I confess.
Using the downloaded exe file worked perfectly at XP command prompt.
Thanks!
Thanks!
Peter Florance
PF Tuning
81 BMW Euro 528i ESP Car
PF Tuning
