do i need a stim to get power to my ecu, i am currently having connection issues with me ecu (brought from phil) i would like to build a power source (if possible) just to establish comms really but if i need a full stim then so be it.
where can i order one from? prefferably pre-built but i can solder if needs be
do i need a stim to power ecu
Re: do i need a stim to power ecu
You don't need a stim. Either use a 9V battery, a plug-in-the-wall power adapter or a car battery.
It is ESSENTIAL that you use a fuse (ideally 1-2A) if connecting to the car battery and a good idea with the others.
A stim does help test other functions but is not essential. In the UK you should be able to get a stim from Phil Ringwood, Bill Shurvinton or I've got a JimStim kit due for delivery.
