I need to stim this format, can either/both the megastim or jimstim do this? I see some mention of cam sense signal but just want to confirm which one to buy.
Thanks!
stim for 8 tooth VR with Cam sense??
Re: stim for 8 tooth VR with Cam sense??
A JimStim with the current release chip can do this.
This page lists them
http://www.msextra.com/ms2extra/MS2-Extra_wheels.html
I don't think it is presently linked from anywhere so you won't likely have seen it.
Thanks for the link, does the 8/1 mean 8 crank pulses and one cam pulse? The flywheel looks to have 8 evenly spaced teeth that pass in front of the VR sensor.
Ah, I think the pattern simulates 8 "crank" teeth for every 1 cam tooth, so not quite what you need. However, with the right cable, you can upload your own wheel definitions to the Stim.
Yes thats what I'm after, 8 crank teeth for each single cam signal pulse, but if custom configs can be loaded anyway I'm sure it will work for me. Thanks!
