hello
i search mod for use megastim v2.0 ms2 pcb3 ( last code extra ) the question is how to use rpm with this stim ?
ms1 set activate a stim in megatune or tunerstudio but where is this for ms2
thanks
megastim v2.0
megastim v2.0
citroen bx 8 valves xu7te home made
V3 - MS2 mainboard.
MS2/Extra 3.1
60-2 wheeldecoder.
wasted spark
LC-1 innovate
V3 - MS2 mainboard.
MS2/Extra 3.1
60-2 wheeldecoder.
wasted spark
LC-1 innovate
Re: megastim v2.0
If I understand the question correctly, you are looking for a stim for wheel mode for MS2/Extra. The answer is that there is no such setup due to the different way the wheel decoder works in MS2 compared to MS1. You need to generate the real signal with either a JimStim or some other device.
Re: megastim v2.0
oups
ok i understand
thanks
ok i understand
thanks
V3 - MS2 mainboard.
MS2/Extra 3.1
60-2 wheeldecoder.
wasted spark
LC-1 innovate
V3 - MS2 mainboard.
MS2/Extra 3.1
60-2 wheeldecoder.
wasted spark
LC-1 innovate
