Just got hold of a jimstim V1.3 and am having a play,looking at the tooth logger and expecting 36-1 am actually getting 35+1 (or that is what it looks like) have tried inverting the output with switches 7 and 8 but no change,am running primary tach with a 12v pull-up....thinking that Q1 could be dead...am I on the right track?
John
P.S. already found the problem of garbage coming out with too much RPM course
PPS. the air and coolant will not go below 54C but I think that could be due to the pots being 10K?
Jimstim 35+1
- Running MSx/Extra
Re: Jimstim 35+1
What does this "35+1" look like?
Have you looked at the tooth log examples page?
http://www.msextra.com/doc/general/toot ... mples.html
- Running MSx/Extra
Re: Jimstim 35+1
Many thanks for your speedy reply,it looks like "" Tooth log of 36-1 wheel on V8 running", but I am sure when I did the same on my Heath Robinson simulator(sewing machine motor,36-1 wheel,VR sensor) the -1 pulse was missing not highlighted?
John
John
Re: Jimstim 35+1
That is no longer an issue with the latest version of the CPU which has firmware v2.0.3john.p.clegg wrote:P.S. already found the problem of garbage coming out with too much RPM course
That will depend which calibration you use for those inputs. With the standard GM calibration, it will go lower than that but other calibrations will be different.john.p.clegg wrote:PPS. the air and coolant will not go below 54C but I think that could be due to the pots being 10K?
