I have a problem with my NEW JimStim V1.5. Firmware is V2.0.3.
If i increase the rpm with the RPM-FINE pot very slowly at the beginning, the LED starts to flash very fast!
After that it seems ok, look:
http://www.youtube.com/watch?v=073r_JLq ... e=youtu.be
Anyone know what the problem is?
I soldered everything twice, but I had the same problem again...
bye
JimStim problem at low rpm
Re: JimStim problem at low rpm
The lowest possible RPM is 60. What you're doing there is that you are putting the fine pot in a position that is just between 59 and 60 so the JimStim starts and stops as fast as it can read the pot value. I'm tempted to say: simply don't do that, it's not needed for testing your MS.
Thank you Jean, maybe changing the code would solve the problem...
