STIMX inj/spk outputs
Why does changing the ignition order not change the order on the stimx board. New to this and basic theory I would think you could see it change.
Re: STIMX inj/spk outputs
No the outputs do not change. They always cycle in the order A through to what ever, up to H. You must wire the outputs so that the sequence matches the correct order.
http://www.msextra.com/doc/ms3/hardware ... iring-ms3x
Cheers Luke
Cheers Luke
