jimstim problem
Building and using the Stimulator to test your Megasquirt
jimstim problem
Postby luke2152 » Wed Jan 21, 2015 11:44 am
Build jimstim couple of years ago and used it without problem every now and again since then.
Last night I was using it testing COP's and somethings gone wrong. When I switch it on (whether or not its attached to megasquirt) it works for a couple of seconds and then U2 and F1 start to get very hot and it stops working. Have been over it as carefully as possible and don't see any sign of anything shorting any of the pins. Any ideas. Don't know where to start testing
luke2152
Re: jimstim problem
Postby racingmini_mtl » Wed Jan 21, 2015 12:00 pm
The first thing to do is to remove the CPU and see if that's the issue. Run the troubleshooting tests here: http://jbperf.com/JimStim/JimStim_v1_5_ ... ml#testing
Re: jimstim problem
Postby luke2152 » Wed Jan 21, 2015 4:47 pm
Yep it looks like it was the cpu. Do you sell them?
luke2152
Re: jimstim problem
Postby racingmini_mtl » Wed Jan 21, 2015 4:57 pm
I do sell them: http://jbperf.com/JimStim/JimStim_v2_0_ ... p.html#Buy. But I'm in Canada so if you're in the US, it will be faster if you get one from DIYAutotune: http://www.diyautotune.com/catalog/jims ... p-310.html.
Re: jimstim problem
Postby luke2152 » Wed Jan 21, 2015 5:14 pm
My bad I thought you were UK based- just going off this:
http://trigger-wheels.com/store/content ... m/JimStim/
I'll try and get one off a UK vendor. Cheers anyway
luke2152
Re: jimstim problem
Postby racingmini_mtl » Wed Jan 21, 2015 6:00 pm
Contact James Murray (jsmcortina on the forum). He's the Jim in JimStim and he's UK-based.
Return to MegaStim
