JimStim 1.5 Questions
Building and using the Stimulator to test your Megasquirt
Ghostin
Post by Ghostin »
Hoping to get some help...
Is there a DB37 connector pinout list detailing which pin is what. Would like to make a jumper harness from DB37 to Microsquirt utilizing the DB37 connector but I cannot find the pinout list. I have seen the jimstim to microsquirt utilizing the board blocks but I would like the pinouts for 1.5/ 2.0 if they are different. Any help is appreciated.
Also when testing my IAC led's my IAC2 will not light, but will light when testing tach signal so I know led is good..all solders look good...any thoughts?
Thanks Guys
racingmini_mtl
Re: JimStim 1.5 Questions
Post by racingmini_mtl »
The DB37 pinout is shown in the MS2 (or MS3) manual in the schematics section. You also have the pin numbers on board silkscreen besides the 19-pin header. And use the FIdle LED for your IAC; the IAC LEDs on the JimStim are for a stepper motor IAC (which is not supported by the Microsquirt).
Ghostin
Post by Ghostin »
Thank you.
