Jimstim problems, checking findings...
Building and using the Stimulator to test your Megasquirt
Re: Jimstim problems, checking findings...
Postby DaveEFI » Fri Oct 02, 2015 1:35 am
The spec of the components is in the Bill of Materials which you'll find in the manual.
DaveEFI
Postby Chiburbian » Fri Oct 02, 2015 5:18 am
Right, but that is the exact part. If everything else is the same can m I use one with higher voltage for instance?
I am trying to avoid paying $3 shipping and waiting a week on a $.60 part. Plus I'd like to get my car on the road soonish.
I don't want to sound ungrateful for the help, I just am looking for alternatives in case I can't find a diode locally that has that spec. Fry's electronics is the best supplier for me locally and they use NTE, and NTE doesn't perfectly replicate every part nor does Fry's keep every NTE part in stock.
Chiburbian
Postby DaveEFI » Fri Oct 02, 2015 6:41 am
With a zener diode I'd tend to stick to the spec of the original. But there is more than one maker of zener diodes, and like transistors may use a different part number for a suitable substitute. Usually called an equivalent.
DaveEFI
Postby Chiburbian » Fri Oct 02, 2015 7:31 am
I found an NTE 134a which seems to match all the specs.
EDIT: It also looks like I fried my processor chip. Somewhere around here I am 99% sure I have a spare chip that I accidentally bought a year or so ago. Crossing fingers.
Thanks.
Chiburbian
Previous
Return to MegaStim
