mega stim testing (question#2)
hello out there_im powering my megastim with a 9V battery only and i have power everywhere im suppose to but i have no ground at the db37 connector will i get a different result if i use a p5 wall wart power source?
Re: mega stim testing (question#2)
Not likely, but I would use the wall wart anyway.thedude wrote:will i get a different result if i use a p5 wall wart power source?
Just one mans preference of course...........
Some clarification: your voltage reading will probably be different because of the difference between the output voltage of the battery and the wall wart, but otherwise your results should be the same.
MS2 v3 w/extra 3.4.2 Release
TinyIOX from JBPerformance
i should see system voltage between pin 1-2 of the "megastim" with the use of a dvom right. do you know of a different wiring schematic other then the one illustrated on the "megastim" assembly page. the ground path that is described looks kinda strange to me.
