toyota corolla
toyota corolla
hi guys i would like to said that thanks to msns + turbo my car is almost where i want it right know 214 h.p and 193 ftq. in a 1.6 engine almost stock ms is doing the fuel,timing,fan,shift light,launch control and i want to drive the tach lets see if i make it work im very
Congrats man-- I'd guess you're right that there's more in that motor with a bit of tuning, 20 psi on an AE92 GZE smallport motor (bone stock) should be closer to 250 or maybe more from other cars I've heard about. I'll know more soon as I've got an AE101 motor I'm bolting back together now though it's not quite stock now, but I won't be boosting 20psi just yet either. I'm guessing this little T25 will run out of breathe at 12-13psi or so. If you want to check it out there are pics on my site in the Cars section...
Jerry a.k.a. 'FoundSoul'
Founder DIYAutoTune.com / AMPEFI.com
The DIY EFI Tuners Guide – How to Install, Configure, and Tune EFI!
Killer Products We've Brought to Life:
MS3Pro, MSPNP and MS3Pro PNP
More info on MSPNP Models
MicroSquirt AMP'd!
MicroSquirt AMP'd!
i already saw or pics nice project too that engine could hold 20 or more psi put a nice t3t4 and you would see the difference.thanks men the only thing that i change in my motor are the pistons,head gasket and the arp bolts all around the engine .i know if i lean more the mixture the engine would make more power a/f is in the low 11 and the timing in like 26 deg. i dont remember exactly right now.
What kind of turbo are you running? What were IATs getting up to? What size downpipe/exhaust? Bluetop cams or?
Got a dyno chart?
Got a dyno chart?
MicroSquirt AMP'd!
MicroSquirt AMP'd!
Which pistons?
MicroSquirt AMP'd!
MicroSquirt AMP'd!
A danish guy making 559HP with almost stock engine. And MS
http://www.powerforum.dk/viewtopic.php? ... hlight=559
http://www.powerforum.dk/download.php?id=2150
That's measured in HK not HP.Johan O R wrote:A danish guy making 559HP with almost stock engine. And MS
Since I don't know what HK is, I converted the torque at peak. It comes out
to 383 ftlb of torque at 7204rpm and that converts to (383*7204/5252)=525.35HP
So, let me eat crow and say that HK and HP are probably pretty close to equal.
Raul
soon to be squirt&sparked 89 mkIII Supra, Using:
MS2 processor (pins 10 & 15 modded), v3.0pcb,
stepper IAC, P&H boards, *ERROR -extra board,
in 6cyl wasted spark configuration.
Jun-10-2007 alpha code.
Re: toyota corolla
Congratulation for your project
What's your ignition setup ? VAST ? crank trigger wheel ?
Test your car horsepower and acceleration with your Android or iOS phone : PerfExpert
Megasquirt successes :
- Opel Corsa A 2L 16v / MS2 speed-density
- Opel Corsa A 2L 16v GSXR750 ITB / MS2 hybrid alpha-n/speed-density
- Opel Corsa A 1.6L 8V / MS2 alpha-n
- Opel Corsa A 1.8L 16V / DIYPNP speed-density
Re: toyota corolla
stock distributor with a msd 6al.
Re: toyota corolla
here some pic of the car
Re: toyota corolla
update went yesterday to the track and my best was 13.6 at 107 miles a lot of wheel spin my 60 foots sucks 2.4 i need to improve that also the clutch was sliping at high rpms so time to do some changes.
Re: toyota corolla
Any cooling problems with the small radiator?
BTW is it cut down or off another car?
Re: toyota corolla
no cooling proble the rad its from a honda del sol the one that came doch.b16.
Re: toyota corolla
Looks good. Should convert it to COP, then you can get that distributor out of there.
Brian
'84 Dodge Rampage
'84 Dodge Rampage
