Does this look right?
Sorry if this is in the wrong section
I went for a power run today on the rolling road, 230bhp @ 18psi (flywheel)
Im convinced the run was not done properly, The power output sounds WAY too low, Ive attached a datalog from the power run to see if anyone can see anything amiss, Can some one please look and give me peace of mind
under boost and higher rpms does it say ZERO o2 volts? is it really that rich? if it is that rich (the numbers approaching the zeros are fairly rich too) then thats your problem. too much fuel. or not enough timing, one of the two.
edit: also, looks like that turbo is a bit too big, doesnt it? it doesnt make full boost until 5500ish, and the dyno pulls end before 6k
1990 Mazda Miata: GM Gen3 V8 swap, 4.8L, custom cam, 2x GT2860R turbos, MS3 + MS3X.
2003 Kia Rio wagon: Mazda B6T/G25MR swap, Miata CAS, IHI RHF5 @ 2bar, LSx truck coils, P&H board, boost control.
Look at the TPS line, Its not held at 100 (WOT)sportage4x4 wrote:under boost and higher rpms does it say ZERO o2 volts? is it really that rich? if it is that rich (the numbers approaching the zeros are fairly rich too) then thats your problem. too much fuel. or not enough timing, one of the two.
If I have any more advance i get det
It was running rich, Which I forgot to check before hand
The turbo under normal road conditions is running full boost by 3500rpm
or somewhere there about 12.0:1 to 13.5:1Avinitlarge wrote:I get told so many different things, I dont know whats what. So what you are saying is set the full boost AFR's to about 12.1:1??
Like it shows on the table here - http://www.msextra.com/manuals/MS_Extra ... m#wblambda
and here - http://www.msextra.com/manuals/MS_Extra ... #WBtargets
like this table (except the map values would be for a turbo) -
Traditionaly the AFR was 12.0:1 or so. That was for safety because most people couldn't afford to install a 3k plus wideband into their car. Also as recently as 4-5 years ago most EFI system couldn't even accept a windband signal input.
A couple years ago the prices started falling, then the LC-1 came along making it foolish NOT to run a wideband. Now all of the real EFI players have wideband nputs, and a couple even have built in controlers.
We can safetly run it for more power AND for more economy too now. I usally aim for 12.5: 1 in boost.
Forget the porn, my bathroom is full of car manuals...
1977 Rabbit (retired)
1991 Cabriolet (retired)
